Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
106 Fragen Alle anzeigen
Frage geschlossen
Why the screen can not turn on?
My ipad3 problem is
- black screen, i try to see with torch, there is no picture at all (apple logo, etc)
- iTunes not detect when screen attached, only dfu mode will detected.
- if i remove the screen, iTunes detect it normally, just need respond for trusted the device.
- if i remove the screen, and try to charging, there is a beeping sound repeatedly.
- i've tried to replace the battery, LCD, do hard reset,
Please help, Please help, :'(
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Try to connect it via DFU-Mode and reset the iPad.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
thanks for reply,
I have tried to connect to itunes in dfu mode and detected. Then I unplugged the usb and do a hard reset, do not produce results, the screen remains dark, then I plug the USB cable back into the laptop, ipad are not detected by itunes.
I do not dare try to do a restore, because the customer forgot his icloud email and password :(
von
Well, he can either lose all his data or lose his iPad.
You should try to check whether the cables are all connected correctly.
Maybe you just got a broken Display and need another one.
If resetting it while in DFU-Mode isnt helping, you should try an other Display. You still can send it back in and get your cash back, if thats not the solution for your problem.
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 104
