Zum Hauptinhalt wechseln
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
56 Fragen Alle anzeigen
HELP! Error Code 70
I keep receiving an error 70 code when I try taking photos. I turned the camera off and back on, but after several photos the error showed up again. Does anyone know how to fix this?
Ist dies eine gute Frage?
Bewertung 7
1 Kommentar
I get the Err 70 code to and can't do any thing else at all and after about a minute the camera shuts off. any help would be nice thanks
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
If the automatic sensor cleaning is enabled, it causes an error 70.
That is, the automation solution is put off.
But I do not know what is the reason behind it.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
thanks seems to have solved my problem "THANK YOU"
von
This is a memory card read/write error. First try to format the memory card. If the error continues after formatting (or the camera won't let you format the card), try a different memory card. If the error continues with a new card then you probably have an issue with the camera itself. Contact Canon for service. I hope this helps.
Bewertung 1
Hey everyone.
My error 70 let me shoot in auto, CA, C1, C2 and C3 on my Canon 7d mark I.
After realizing I need to somehow update my firmware and that you cant update firmware unless in settings P, Tv, Av, M or B Ifound that if I set the camera to video I could use P and update the firmware I had loaded onto a formatted memory card!
Hope this helps someone else!
Bewertung 1
I had this problem toobut the solution is to deactivate the autocleaning. The it shoots nornaly
Bewertung 0
4 Kommentare:
I have this problem too and have format the card but still writing error 70
von
Please help me
von
Have AUTOCLEANING set to OFF
von
Please check image Sensor
von
Hi, i fixed this error on my EOS 600D with Tornado EOS program. Do factory reset and problem solved.
Bewertung 0
1 Kommentar:
what do you mean Tornado EOS program?
von
I faced the same issue on my 60D.
Tornado EOS programn is really awesome! I used the free version to upgrade the firmware and problem solved!
Bewertung 0
Antwort hinzufügen
Tyler Vaal wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 27
Letzte 30 Tage: 105
Insgesamt: 24,945
