Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Charging keeps changing from 2% to 3% and then to 7%
The iphone 5s is with Sprint. It is having issues with charging, it cycles between 2%, 3% and 7%. It has been doing this for 2 days now. If the batteries dies and the phone turns off, it does not charge and stays on the battery with drained capacity icon. I have changed the battery but the problem persists. It may not be the charging port because when I unplug it, the drained battery icon changes to lighting and tip of the cable...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
It sounds like it possibly could be a problem with the U2 chip. This is a chip on the board that when it fails won't charge the battery specifically when the battery gets really low.
The failure can be caused by using non-Apple chargers.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thank you James for the quick response!!
von
tnk james
my 5s have this problem too
von
There are a few things you can try. To see if it's the u2 chip. However, if it is, you're probably going to want to send it to a quality repair shop. Like Jessa Jones
Bewertung 2
1 Kommentar:
Thank you for the quick response!!
von
Rule out bad battery and back dock connector. Then rule out FL11 missing gas gauge filter on the board near battery connector. If none of that solves, it is U2 charging logic ic.
Bewertung 0
1 Kommentar:
Dear Jessa,
Thank you for the prompt response! FL11 is present and I checked for the continuity at FL11 near the battery connector next to C279, it checks out (the multimeter beeps). Just to make sure that is what you have implied.
von
Antwort hinzufügen
Aashish Shrestha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 106
