Zum Hauptinhalt wechseln
Repair guides and support for desktop computers produced by Asus including towers and all-in-one display PCs.
158 Fragen Alle anzeigen
no signal from computer to moniter
Their is no signal from my Asus essentio to the monitor . The monitor is working fine as I have cctv cameras attach to monitor and it is displaying them fine, I have also checked cables which are all fine. This has lead me to believe that this could be the graphics card . I have taken a look inside the computer and I can t see the normal set up with a removable graphics card attached to the vga port so I am now wondering if the whole motherboard needs replacing. Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
haguehags ,
Hope This answer will hep you to get idea to fix you PC
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
this isnt hel[ full
von
Greetings,
Check the monitor for which type of input signal it is currently set for.
- there should be a choice within the set-up options for Dvi, HDMI, Display port or whichever cable type the Pc is connected to the monitor with.
- insure that the cctv cameras are not set as the default source.
Hope this helps in attaining a signal.
Bewertung 1
asus pentium3 power ok ram clean ok showing signal ditected
Bewertung 1
Antwort hinzufügen
haguehags wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 32
Insgesamt: 4,342
