Has anyone done a screen repair on a Galaxy Tab A?
Hello! I have a potential customer with a shattered screen on her Galaxy Tab A 9.7". I cannot find anything that shows how the screen comes off. Have any of you repaired a shattered screen on this model? Is it the same as another Galaxy tablet model? Any info you have would be greatly appreciated.
Ist dies eine gute Frage?
4 Kommentare
I know this is an old thread but can anyone tell me if the difference from sm-p350 and sm-t350 screen module? Is there a different connector for the active screen or do they both use the same hardware? The reason for asking is I am trying to see if I'm able to mod a smt350 to use an s pen because if the hardware is identical I may have a chance at doing this.
von Jeremiah mossman
@grungbuk the difference is in the sensitivity of the digitizer The sm-p has a more precise touch sensitive screen than the sm-t
von Jimfixer
@grungbuk The difference is not only the connectors but also the shape of the back of the LCD assembly. The T350 has the two pop connectors for digitizer and LCD and is a perfect rectangle. The P350 has a third connector which is a ZIF and has a 'hump' at the top of the LCD where the connector is. No way to use an S-pen on the version without due to that and differences in the mainboard.
von Beach Fixer
You have to heat it up and then slowly work around the edge lifting the old screen. Then make sure you scrape all the old adhesive off the frame all the way around. That's how I did mine.
von Tony G
