Steering is pulsing and hard to steer
Power steering on 2002 Altima 2.5 is pusing. Seems to be only working for a second then like manual then power etc
Ist dies eine gute Frage?
You really need to take this to the dealer to have the p/s system tested
with a pressure tester to determine if it's the pump or the steering gear; it could be either. Otherwise you can only "throw" parts at it.
I'm assuming the fluid level is OK?
War diese Antwort hilfreich?
Whenever the steering becomes stiff, the first port of call is the steering fluid reservoir, for the sake of a few £'s or $'s you can simply top up the reservoir to the required point and normal service is resumed! If this fails then you need a better informed opinion such as a garage!
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 4,542
