1994 toyota pickup dies when put into gear
Have a 94 toyota pickup and when you put it into gear and take off it dies like you turn the key off not sure if it's a ground wire problem or what any ideas are helpful
Ist dies eine gute Frage?
It's not likely a ground problem. Probably a sensor. The only time I have had trouble with my truck not running it has been a sensor. Check all connections, unplug and plug back in. You'll probably fix your problem.
War diese Antwort hilfreich?
You should also check to see it it's getting fuel when you have this problem. Could be a weak fuel pump.
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 330
Do you have the same issue when it is not in gear? It only happens when you drive?
von oldturkey03
