Can use is iPhone 5c housing in iPhone 5s?
I used iPhone 5s and want to change look like 5c.
This is possible?
Ist dies eine gute Frage?
This is possible?
I.. Well.. I.. Don't think so? So many problems I could see happening. Had a similar idea once, except mine was to change i5 to i5C. Which isn't possible. What you're proposing, could be possible. However there is one big challenge. Now it does appear, that you could change out the Lightning dock. They appear very similar in shape and screw bracket layout. So that could work, which you would need for the home button. The logic board layout is very similar. So this could possibly work, keep in mind, I haven't tried it myself. So, the one problem with this, is the lcd socket. You'd need to micro solder the socket for an i5C, onto the i5S logic board. Then swap the board, and the Lightning dock. The battery is already swappable. Now you've got my interest peaked. Is this possible?
War diese Antwort hilfreich?
so, it should not be. thanks :)
Not sayin never. Just saying not easily done
Would the iPhone 5s screen not fit in 5c housing?
Not stock, no
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 306
