Zum Hauptinhalt wechseln
7.1 megapixel camera by Canon, model SD750.
9 Fragen Alle anzeigen
Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
No memory card in my camera
von
Use the camera to reformat the card.
von
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
von
When it says no card what will you firmat bro
von
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Did you get my last response?
von
I guess not. All I got was that one
von
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
von
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
von
Antwort hinzufügen
mesarey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 5,104
