Zum Hauptinhalt wechseln
The GoPro Hero3Plus Black Edition can be identified by its model number: CHDHX-302. It's an eighth generation camera that was released in October 2013. The GoPro Hero3Plus Black Edition is a Wi-Fi capable, 4K resolution digital camcorder.
GoProHero3+ Silver Rear Case Is it compatible with the GoPro 3+ black
Hello,
Someone knows if this reference : GoPro Hero3+ Silver Rear Case : [verlinktes Produkt fehlt oder ist deaktiviert: IF300-031]
Is compatible with the gopro hero3+ black edition ?
Because this one : GoPro Hero3+ Black Rear Case is out of stock.
regards
Replace the metal and plastic rear case frame for the Black Edition GoPro Hero3+. Bild
Produkt
$10.99
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Hello,
I'am in the same case, I need a rear case for my GoPro 3+ black but it is out of stock.
I study the motherboards of the GoPro 3+ black and silver on photos and the unique difference between both it is a contact point between the motherboard and the batterie enclosure. They are not in the same place but there is not a big difference of location (it is lower on the 3+ silver motherboard) . I don't kown to what this contact point use.
There is the same difference in the rear case for the contact point in the batterie enclosure.
It is possible to see that in this photos:
Contact point in the motheborads
GoPro 3+ silver: http://g01.a.alicdn.com/kf/HTB1FS_OIFXXX...
GoPro 3+ black: GoPro Hero3+ Black Motherboard
Contact location in the batterie enclosure
GoPro 3+ silver: [verlinktes Produkt fehlt oder ist deaktiviert: IF300-031]
GoPro 3+ black: GoPro Hero3+ Black Rear Case
Everybody know well the gopro and can help us?
Regards
Replace a corroded, damaged, or malfunctioning main circuit board assembly. This part is compatible with the Black Edition of the GoPro Hero3+. Bild
Produkt
$59.99
Produkt
$10.99
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for your detailled explanation
von
Hi,
Do you bought the GoPro 3+ silver rear case?
Bewertung 0
No, sorry , i wait more information
Bewertung 0
Antwort hinzufügen
lacombe julien wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 728
