Zum Hauptinhalt wechseln
Dritte Generation des Surface Pro Tablets ab 20.Juni 2014
What is the version of my LCD screen?
Hi everyone,
The touch screen of my Surface pro 3 was broken so i tried to take off the touch screen from lcd but I did not succeed to save the LCD. So now, i try to buy a new one but i don't know the version of my lcd because I inconveniently threw the flex cable between the touch screen and the motherboard. So, is there anything i can do to know the version of my current LCD ?
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
same, I have a surface 3 that I recently broke, but I don't want to open it without having a replacement screen first, but I don't know which version I should get. any way of knowing how to tell which version it is by the outside?
von
Any luck with identifying the version?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The model number on my Surface Pro 3 is written in very faint writing on the underside of the kickstand.
Mine says Microsoft Corporation Model: 1631
War diese Antwort hilfreich?
Bewertung 2
If you type in the actual model number which is on the back of the device you will be able to get a screen type by just typing in #### replacement screen. That will get you the exact replacement screen. For a Surface Pro 3 I think they are all 1631 screens. Look on the back and see if you see Model # 1631. If not just replace your model number in the #### spot.
Bewertung 0
3 Kommentare:
Type in actual model number where?
von
I too need to know where I can type in the actual model number.
von
google: 1631 replacement screen
von
Antwort hinzufügen
Gaetan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 4,936
