Hi,
Blinking red light indicates low battery (when phone is not connected to charge). It should turn to a steady red light when charging. Is it steady when you have connected the charger?
If not, you probably have a faulty battery or faulty charging circuit in the phone.
If so, how long have you left it on charge? Leave it on charge for 1-2 hours and see if it starts to charge.
(I suggest this because I had a android phone with a completely flat battery which initially did not respond to the charger, so with nothing to lose I left it on charge, after 1.5hrs it suddenly kicked into life and started charging and subsequently took another 3 hours to fully charge - and has been good for over 12 months now charging normally)
If it does not respond at all after you have tried the above you probably have a faulty battery or faulty charging circuit in the phone. Check your warranty details and if still valid contact the maker.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
14
11 Kommentare
Sir I am also having the same problem that my mobile p8 lite doesn't charge , when I connect the charger .. the battery percentage does not increases, it stays the same .. Sir please guide me the suitable solution ... waiting for your reply ....
von masood ahmed
hello iam using huawei p8 lite my problem is that when i connect my mobile with my laptop my mobile shows the charging but not save how to fix it .
thanks
von Faraz Ahmad
Huawei p8 lite not charging even after replacing the charging port,
What else can l do to fix it please
von vumbata
i have huawei gr3 2017 known as huawei p8 lite 2017 or huawei honor 8 lite
with a battery problem
but after changing it does'nt increase in charging porectage
the screen is on when i put the charger
but there is no ''electrecity logo " in the battery poucentage
von Yass_ IN
use a good 3.0 mah charger or 2.5 mah charger. it works sum time 2mah or 1 mah charger was drain the battery's be cues of low amp and charging I-C temperate get hi and drain the mobile battery.
von TaMooR BaLoch
6 weitere Kommentare anzeigen
