Zum Hauptinhalt wechseln
GSM iPad 2 mit 16, 32 oder 64 GB Speicherkapazität und einem Dual Core Prozessor. Modellnummer A1396. Die Reparatur ist schwierig und verlangt Hitze und Hebeln.
151 Fragen Alle anzeigen
How to remove resistors from the logic board of a ipad 2?
Hi I am trying to use the hardware method of removing icloud lock from an ipad 2 3G and WiFi.
I have gotten into the ipad and removed EMI shield, identified the resistor that needs to be removed (r1205)
Now, I'm going down to the shops today to bag meself a basic solder iron.
My question is, how do I exactly remove the resistor with the solder gun? I've never used one before.
Looked all over YouTube etc, no help whatsoever which is a first!
Please help?? :)
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Albusdumbledore, you do realize that this will limit the capabilities of your iPad. I would not expect the holy grail of iCloud unlocking from removing those resistors. Also, you do realize the size of those is only 0.4mm x 0.2mml. So you will need a proper soldering iron with a microtip and a source for magnification. To hot and you'll destroy the pads, to cold and you'll tear the solder pads.Practice on an old board first. Usually this size of component comes off with just the heat from the iron.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Hi oldturkey03! Many thanks for your reply.
I do realise this can take away the capability of the 3g function of the ipad.
Thanks for your advise it's helped a great deal. I bought a basic soldering iron from maplin ealier. I'm going to try it and it's no loss to me if I mess up. Hopefully I will get this right. Do you have any idea what sort of temperature I need it at?
I also have a craft hot-knife with a very fine tip. Would this work better?
YouTube doesn't help a great deal.
There are guys on eBay that offer this service, it cannot be ultimately impossibly difficult I hope.
Thanks again.
von
Antwort hinzufügen
Albusdumbledore wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 5,259
