Install bigger SSD possible with latest model?
Is it possible to replace the internal ssd with the latest 2015 model?
Ist dies eine gute Frage?
Sure it's possible. The problem is obtaining Apple's proprietary SSD. Here's how to do it: MacBook Pro 15" Retina Display Mitte 2014 SSD austauschen
OWC says you can do it but provides nothing to do it with, as yet.
This is a quote from OWC:
Apple does not intend for end users to upgrade the SSD in these models themselves. The company even has used uncommon "pentalobe" screws -- also called five-point Torx screws -- to make the upgrade more difficult. However, access is straightforward with the correct screwdriver, the SSD modules are removable, and Apple has not blocked upgrades in firmware, either.
As a result, third-parties, like site sponsor OWC have released SSD upgrades with a compatible connector for the "Mid-2012" and "Early 2013" models. Specifically, OWC sells the compatible Mercury Aura Pro SSD and provides the needed screwdriver as well as an Envoy Pro bus-powered external enclosure so the original SSD can be repurposed as an external drive.
OWC is hard at work on compatible SSDs for subsequent models and plans to release ones soon. In testing of the "Mid-2014" systems, OWC discovered that when a "blade" SSD from a Cylinder Mac Pro is installed in one of these systems, it "negotiates a x4 PCIe connection versus the stock cards, which negotiate a x2 PCIe connection." This means that the Retina Display MacBook Pro provided more than 1200 MB/s drive performance, a huge jump from the standard SSD.
Apple boasts that the "Mid-2015" systems have "up to 2.5 times faster flash storage than the previous generation" of 15-Inch MacBook Pro models. In independent testing, OWC confirmed these models have read speeds around 2000 MB/s and write speeds around 1200 MB/s. These numbers are in line with Apple's performance claim compared to the SSDs that the company offered with the previous models, but not compared to the maximum speed that the previous systems unofficially can support.
Consequently, all of these models can support larger SSDs than the ones provided by default, but some models support faster SSDs, as well.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 13,670
7 Kommentare
What do you want to put it into?
von mayer
Into the 2015 model. I think of order it with smaller ssd size and get a bigger one from amazon to replace it...
von Christian Staudacher
Right now that's a bad idea as Amazon ( or anybody else) doesn't have one that will work. Looks like their army of attorneys have the technology locked up for now.
von mayer
OWC now has replacements SSD's for current models - http://eshop.macsales.com/shop/ssd/owc/m...
von Glenn Schwab
Here is the correct OWC page for your system: MacBook Pro with Retina 13" & 15" Late 2013 — Current
von Dan
2 weitere Kommentare anzeigen
