Here is the troubleshooting steps to fix the brother printer is printing completely blank pages windows 10
1. First of all, you should restart the devices, and then give a print command.
2. Let’s cancel all print command, and then visit the printer properties, let’s see if your printer is showing available in the queue or not?
3. Most of the time, people are getting the blank page from their brother printer due to the ink cartridge issue, so you need to assure that your printer has enough ink to print a text on the paper, if it doesn’t have enough ink, you may replace the ink cartridge as well.
4. Apart from this, you may have the ink cartridge issue due to the installation issue, so you should uninstall the ink cartridge and reinstall the cartridge again. now give a new command, let’s see if your printer is allowing you to print a document or not?
5. Sometimes, you may be getting the blank pages as an output due to the driver issue, whenever your printer is not printing the documents, you should take out the driver from your pc, and install a new driver on your pc.
6. After using the above steps, if your printer is not allowing you to print anything, I will suggest you to factory restore your printer, and then reconfigure it.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
7
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
12 Kommentare
Hi,
Have you tried printing a colour copy of a page, by loading a page with colours on it into the printer, using the copy function on the printer itself and pressing Color Start? Does it come out B/W or Colour? If colour is printed then at least it proves that your printer can still print in colour, which is a start to finding out what's wrong.
von jayeff
Colour simply does not work. It's not a file transfer issue from the computer. Using the colour copy setting will not do anything either. I'm curious what I may need to clean to get the ink to flow out from the tanks.
von SM
Also, mine is 250c not 240c
von SM
Hi,
Sorry about thinking it was 240c I can only surmise, like you, that the printhead has become clogged with dried ink due to not using colour that often. The cost of replacing the printhead exceeds the cost of a new printer. I can only relate to you my experience with my Brother mfc 440cn which had the same problem, not as bad, would not print magenta or yellow. I ended up doing a printhead clean operation 7 times, which I know is wasteful of ink, but I couldn't print red or yellow anyway and their cartridges were full (you can select colour as a clean option so you don't waste black). It worked, although I had to do it one more time as the yellow was still intermittent. I have since worked out how to prevent this problem, if you do not print in colour that often. Leave the machine in sleep mode. I found that it would "wake up" every so often and do a quick printhead clean then go back to sleep. I hardly print in colour but for over 3 years now have not had a problem. I am using generic brand ink refills
von jayeff
Hi SM
According to my experience with the MFC-240, I can fully support what jayeff just said.
If his recommendation does not work out there are still two more options. First, you may start a power purge (cleaning) procedure, using the printer's "service mode". I could send you the instructions how to activate this in case you need it. It is not complicated, just a strict procedure of steps you have to follow.
The next option is to open and disassemble the printer and to clean the print head with distilled water. I did it, and it helped. However, for doing so, you need a service manual for the MFC-240, and quite a bit of courage ;)
von Markus
7 weitere Kommentare anzeigen
