Zum Hauptinhalt wechseln
GSM iPad 2 mit 16, 32 oder 64 GB Speicherkapazität und einem Dual Core Prozessor. Modellnummer A1396. Die Reparatur ist schwierig und verlangt Hitze und Hebeln.
152 Fragen Alle anzeigen
Frage geschlossen
No Plastic flap on SIM/Front Facing Camera - how to fix?
Hey guys,
i bought a defective iPad 2 on ebay but the guy who owned it before seems to have used wrong tools.
There is no "plastic flap" which holds the cable in its place anymore - so the cable is not able to make contact..
Foto of Plastic Flap (c) by iFixIt
(The black small "flap" is missing)
As a workaround I put a small piece of paper under the cable - now it works partially - front facing camera works, SIM is still not recognized. But I want a bulletproof solution ;-)
What should I do to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Order this and remove the black plastic tab and manually install it on your ipad http://www.ebay.com/itm/2-PCS-FPC-SMD-Di...
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Ha!! Great! Thanks!
Could you confirm this is the same item
http://www.ebay.de/itm/iPad-2-3-4-Digiti...
Going through this should do it, right?
https://www.youtube.com/watch?v=U6T01c64...
Thanks for your quick reply!!
Jonas
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 53
