Zum Hauptinhalt wechseln
The Sprout Channel Cubby™ was first produced in 2014, it is a child friendly device that provides the functionality of a tablet. It boasts a 1024x600 touch screen, Two 2 megapixel cameras (one rear facing and one front facing), Parental controls and security, HDMI connectivity, Bluetooth, WiFi, 16GB Memory, 1GB RAM, and a 1.2 Ghz processor. It has access to internet and various application stores and applications, which can be limited by the parental controls
Why wont my device charge when plugged in?
when i plug in my device it does not charge why is this?
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
My device want charge at all or it want come on at all need help please......
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hello,
I am getting nothing when trying to charge my cubby. The device won't even turn on. Thanks Jeffrey_Hemingway@yahoo,com
von
It is possible that you don't have the adapter fully in the charging port or it is possible your charging port may need replacement. Before attempting to replace your charging port check to see if the cable & adapter will charge another device it is possible it is a faulty cord or adapter
Bewertung 0
I found a battery wire that is soldered to one of the three pads on the main board was not connected they felt tight but were being held in place by the plastic insulation. I stripped back the insulation(about 1/16 inch) and resoldered the connection
Bewertung 0
maybe its your cable not working probably, i suggest you get a new one. I reckon it won't be too pricy
Bewertung 0
Antwort hinzufügen
jasen biggins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,725
