Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Frage geschlossen
My iPhone is turning off itself
Hi
My iphone is turning off a lot of times even the baterry is full. When I turns it on it ask me to take the password after restart :( It is like when I make hard reset. Sometimes I must connect to wifi because my signal is searching and the time is not set. Where can be mistake ? My baterry was before changing a housing in very good condition and I didn't have problem with it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There a many different things that could be causing this problem, including things like liquid damage. However, as you have an iPhone 5, the most likely scenario is that your battery is failing. Failing batteries will appear to be normal when charged (they will look like full batteries), but will quickly drain and power off. You can take your device to an Apple store, and they can test the battery for you. iOS batteries typically last around 2-3 years.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hi thank you very much and I try change baterry because when is iphone charging then Iphone haven't any problem :) I think it is problem with baterry but I don 't know why because before change my housing, baterry lives more like 1 day by normal using ...
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 60
