Zum Hauptinhalt wechseln
Guides and repair information for the Lenovo Thinkpad T430, a 14-inch business laptop by Lenovo.
20 Fragen Alle anzeigen
Power button LED Blinks when I press power button.
Lenovo T430. Tried following steps, No luck. Refer to my Video here.
  • Try charging the Battery to Full
  • Remove Battery and tried booting it with Power directly.
  • Changed the Keyboard.
  • Removed the Bios Battery and tried to switch on.
  • Removed the RAM and tried to switch On.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
6 Kommentare
Is there a pattern to the blinking?
von
No It just lits up and turns off. I dont think it is a pattern.
von
is there one or two sticks of ram
von
Do you get any fan sounds? Do you hear the hard drive spin up at all
von
yes i hear a fan sound, it comes and goes off (the sound)
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try removing one stick of ram if you have two and test one stick at a time in each of the two ram slots. Then test the second stick of ram in both ram slots this will tell you if you have bad ram or a bad ram slot. if it still doesn't work you need to consider getting out a multi meter and tearing open your computer and testing the circuit board starting at the power outlet and working into the board
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
I tried the RAM swaps , no change. Also Fan wont turn on. I am not familiar with electronic circuits.
von
Even now 2021 i have that problem on my Lenovo All-in-One Computer IdeaCentre 300-23ISU (F0BY0041US) Intel Core i3 6th Gen 6100U (2.30 GHz) 8 GB DDR4 1 TB HDD 23" Touchscreen Windows 10 PRO 64-Bit
von
I have a T430 with the same issue. LEDs (power Fn F3 ) are blinks one but the laptop does not turn on.
I triedtoclean the connections, remove the batteries....no change.
Once i removed the RAM and the unit booted up.
So the issue is the following : it works with no RAM, but it does not work with installed RAM.
The problem is the same with the old and a brand new RAM also.
Any idea?
Bewertung 0
Antwort hinzufügen
ksenthilbeit wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 30,837
