Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
549 Fragen Alle anzeigen
No Power, #1 LED Stays lit, #'s 2&3 LED's flash
I have an Intel iMac 20", Model A1224, 1gb RAM, that one day just stopped turning on. I opened it up and checked the diagnostic LED's on the board. #1 stays lit. #2 and #3 blink on and off. #4 doesn't light up at all.
When I press the power button on the back of the black, plastic case, the internal fans will attempt to spin, but will not spin. (They rotate *maybe* one (1) degree out of the 360 degrees they would spin.) I can hear a high-pitched sound--kinda like a whirring sound--coming from the power supply when this occurs.
I have attempted to reset the SMC with, seemingly, no effect.
Any advice would be much appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
I have the same exact issue. Replaced the power supply and 2&3 are still flashing. Did you find out the problem?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The blinking indicates a RAM problem. First reseat the RAM. If that fails try one stick at a time in each of the slots.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Excellent low cost suggestion. +
von
Seems that the power supply has gone. #1 LED indicates trickle power, it's always on when the computer is plugged in and supplies 5V to the logic board. Whe #2 and#3 are blinking it means that CPU and GPU can't be initialized. Usually a (don't know the english term for it, i try ;-)) power store diode is gone on the power supply. You can check it but be careful. Leave the machine unplugged for at least 24H cause the capacitors can store a lot of voltage.
Good luck.
Bewertung 1
2 Kommentare:
Installed a new Power Supply. #2 and #3 LED's are still blinking. Any other thoughts? Thanks.
von
I have the same problem. I also changed power supply and the problem still there. Any answer?
von
Antwort hinzufügen
Plumberman010 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 20
Insgesamt: 3,124
