Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2011 / 2.5 & 2.7 GHz Core i5 oder 2.8 GHz Core i7 Prozessor
Upgraded to El Capitain stuck on past splash page
I just upgraded an iMac to El Capitain and it stuck on the splach page. It would boot but just get stuck at the splash screen, loading bar would go all the way but then just get stuck,tried booting to safemode , ran disk util and to get to the terminal and played around in there nothing. Anyway decided to reinstall and its no joy stuck in the same spot. so I shut it down and decide to take a break from it . come back after 2 hours and figure id give it another try start the computer and it boots fine. Can anyone tell me whats going on . I dont want to return the machine till I know its going to work fine Can some of you Mac gurus give a hand here
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
5 Kommentare
Jim, you know the drill - last four figures.....
von
the last four digits are DHUF
von
Look again on the bottom of your stand, those numbers do not work.
von
sorry need my glasses its a j not a u DHJF
von
Apple iMac "Core i5" 2.5 21.5-Inch (Mid-2011) Specs
Identifiers: Mid-2011 - MC309LL/A - iMac12,1 - A1311 - 2428
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Did you change the hard drive or anything else? Seagate 1 TB hard drive?
Almost as useful as a T8: https://www.micromat.com/products/techto...
War diese Antwort hilfreich?
Bewertung 3
7 Kommentare:
When the original update was don it was on a NIS it was then unmounted and move to do further testing it booted without the NIS so remounted it and it seems to be running fine now so I think it was the NIS . Im gonna check the logs now that its booted and see if thats the reason
von
What's a NIS?
von
Thanks for the help
von
NIS is network information service a client–server directory service protocol for distributing system configuration data
von
How's that working for you? Never used one, sounds like PC or UNIX to me.
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Jimfixer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 46
Insgesamt: 728
