My laptop is beeping 7 times...Please help?
Thanks,
Nancy
Ist dies eine gute Frage?
Thanks,
Nancy
nancycat75 seven beeps on POST could be a processor issue. Start by removing the AC adapter, memory module and the battery, then hold down the power button ~20 seconds. Then plug in the AC adapter replace one memory module and try to power up the computer. See if you can perform a Pre Boot System Assessment (PSA Diagnostic) by holding the “Fn” while rebooting the system. Keep holding "Fn” key until the diagnostic gets initiated. Here are the details on that
If no change you can also try this:
1. Remove main battery.
2. The rear plate for the system is held on by 6 screws. Remove all 6 screws and remove the plate.
3. With the battery compartment nearest to you in the top left corner you will see the CMOS battery.
4. Using a minimal amount of force and a flat tool, pry the battery gently from its seat (it is held on by sticky substance).
5. Unplug the battery from the motherboard by disconnecting the white connector.
6. Wait for two to five minutes and then reattach the battery cable and reseat the battery.
7. Replace the rear plate and the retaining screws and reseat the main battery.
8. Attach the AC adapter and power on the system.
9. If a 5 beep code is heard, switch off the system and restart it.
10. When the system restarts and completes POST successfully, browse to the Drivers and Download page
11. Download and install the latest BIOS Version. from here
from here
War diese Antwort hilfreich?
Usually seven beeps means a problem with the CPU
According to the manual may be a fault in the test cache CPU processor possibly caused by failure or motherboard failure
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,496
