Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Vibrator not working on iPhone 4S
Hello everyone !
After changing the screen of an iPhone 4S that was dropped, I check all the different part. And I notice there is one thing which doesn't work : the vibrator.
I did not know if it's my fault, so I disassemble again the iPhone and I check if the motor contact (two little springs) are aligned with the contact motherboard, it seems good, I cleaned them with alcohol to be sure.
I reassemble the iPhone, but the vibrator still doesn't work... :/
All of the other part are ok :
Volume buttons : OK
Mute toogle : OK, when I switch, the iPhone display me a popup
Headphone jack : OK, when I plug headphones, the sound is ok.
How to be sure it is the vibrator motor that is defective ?
Is there a simple way to "test" this part, for example branching an alimentation on the two little springs ?
I just want to be sure it's not a faulty cable...
Thanks !
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hello Julien,
Unfortunately over time the vibrator motor on iphones can wear out. For myself, my iphones ringer is always set to vibrate, and I am suprised it hasnt gone out yet. If you know somone who has a functioning 4s motor, trying testing their motor in your phone. If it works, then you know your cable is working. If The new motor doesnt work you'll have a better idea of what all needs to be repaired. If you do need to order a new motor, iFixit sells them new or used (CDMA/Verizon only) and you can find them by searching this part #115-015-1 on the website.
Best Wishes!
Jordan
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thx for your answer !
So, there is no other way to know if it is the vibrator himself or something else ?
The other fonctionnality works great, so I suppose the cables are ok no ?
I don't have another iPhone 4s...
Thx again !
von
Antwort hinzufügen
Julien wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 54
