Zum Hauptinhalt wechseln
Harman Kardon Lautsprecher mit Appleeigenem Anschluss. Hersteller Modellnummer M8756
How to take apart the Amp of the Apple Pro Speaker?
Hey, my G4 Cube speaker recently has the cord of amp loosen. I want to open tge amp case to fix it. But I couldn't find any source in the internet. Could you please assist?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
6 Kommentare
Thank you for your reply. My Apple Pro Speaker is the one come with the G4 cube, which has a translucent shell for the amp. I woul like to know the way to open the shell without damaging it.
Thanks anyway:)
von
Is there a identification number on it? Like an A1122 number?
von
I don't know. But the picture in this link shows the speaker:
http://blog.pardner.com/2012/08/using-th...
von
So far I found only this picture
http://www.audioimprov.com/AudioImprov/S...
von
Thank you. But the auther didn't tell how it was open.
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
See if this guide will help you: Verwendung der Apple Pro Speaker mit einem Klasse-D-Verstärker.
UPDATE
See if this guide is what you need: Repairing Apple Pro Speakers Loose Cone
Apple Pro Speakers M8756 Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
20 minutes
Anleitung
Schwierigkeitsgrad:
Mittel
30 - 45 minutes
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
for anyone else:
I just recently popped my Cube amp open as well. It seems like it's just glued shut, but it's not a chemical glue so you should be able to pop it open with minimal difficulty. I used a piece of sheet metal about the thickness of a razor blade, so a razor blade itself would probably work to open it up.
Just be careful because the bottom half has a groove that the top half actually fits into; you can't just slice a razor straight down because it will hit the bump.
Bewertung 2
2 Kommentare:
Hey Josh what was your experience getting the inner shell open? I'm at that point and am concerned about damaging the plastic in the process. Any pointers? Thanks!
von
Just kidding. I managed to get it open easily by working a scalpel into the corner near the cords and then slid a sheet of thin metal like you mentioned slightly farther down and it came apart relatively easily. From the bottom end where the output is, I worked across and the whole thing eventually opened like a book. problem solved!
von
Antwort hinzufügen
chogokinaholic wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 2,011
