Hi,
You need to hard reset your phone.
Before you do this make sure that the battery is fully charged.
Warning : A hard reset will restore your phone to factory default. You will lose all downloaded apps and user data!
To perform a hard reset do the following:
1.Turn off your phone
2. Press and hold the Volume Up + Power button (both together) until you see Recovery mode.
3. Release both buttons.
4. Select option "wipe data/factory reset" from the menu.
(To scroll options use Volume buttons, and to confirm press Volume Up key for 3 seconds).
5. Then confirm "yes" by Volume Up.
6. In the end accept (confirm with Volume Up key) operation "reboot system now"
The phone should now reset, be patient it takes a few minutes.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare
I have done the same but nothing changes still whenever I switch on my phone screen comes p by writing canvas on it & after that it gets stuck nothing happens later to this.
von Rats
Hi,
I found this link which may be of interest to you. http://forum.droidarena.in/Thread-How-to... First he states that you press 3 keys (power + vol up + vol down) to hard reset. Different to what I have found (and you as well) elsewhere. Maybe you could try that before deciding IF you want to try his other option.
von jayeff
