Zum Hauptinhalt wechseln
The Dell Venue 11 Pro is a flexible slate tablet built for business. It comes with many work-oriented features, including Windows 8.1, a removable battery, and a variety of docking solutions.
11 Fragen Alle anzeigen
will not charge. How to fix it?
I've connected the battery charger to the tablet and nothing happens, white light that indicates chaging does not come on the tablet. When I connect the charging cable to the travel keyboard connector the light comes on indicating that it is charging. How can I get the tablet to charge?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Check to see if the light on the power supply goes out when you plug it into the tablet. If so the problem may be the USB charging port board may need replacing. If you open the tablet it is a good idea to replace the real time clock battery if this has not been done.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Char1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 2,385
