Zum Hauptinhalt wechseln
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 Fragen Alle anzeigen
Will not boot every time.
The iBook will not open every time the start button is hit. After resting for 6 hours with PS connected, it will open up and is then running perfectly. If then closed down, it will not reopen. A brand new battery did not help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
I deserve the noble nickname "stupid".
Of course a new battery should have ample time to charge itself.
It will not happen after just two hours of charging, in my case it went on full capacity after 16 hours of
constant connection to the PS. Sorry for the trouble and thnks to Machead3 for his suggestions which never came to use
Hans
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Could be
your HD is going. Boot from install CD/DVD and run Tools -> Disk First Aid, repair disk and repair permissions.
If this answer was helpful please remember to mark it accepted.'
Good Luck,
N.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Hans Elfelt Bonnesen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 818
