How do i get under the board to replace a "switch"?
how do i get under the board to replace a "switch"?
Ist dies eine gute Frage?
It's possible the switch is bad, but that's not the first thing I'd look at. To replace the topcase (which has the switch on it) requires removal of the topcase, and I believe there is an iFixit guide for that. Does it do anything at all when you power on? If not, have you tried another known-good AC adapter? I would remove the Airport, extended memory, and battery, and try to reset the PRAM and PMU, which can sometimes jumpstart a system. Also, when the AC adapter is plugged in, does it show a light on the plug, and if so what color and is it steady or flickering?
War diese Antwort hilfreich?
i meant the button that turns it on.. no.. nothing is happening.. for a long time it would boot up one time a day .. but no more
i think my husband did take it somewhere and they tried it with different ac adapter but it did not come up but the light on our adapter does come on.. steady... what i have is an original apple apple ac adapter.. they suggested it was the mother board..
it does have to come up to reset PRAM and PMU, right? in case it does.. remind me how to reset.. the battery quit showing up before all this started happening..
thanks for your help.. i got this for my husband on ebay and he's very disenchanted with macs.. which i love...
Likely it's the guts of the computer, and the power button is just the messenger telling you the bad news. Reset the PMU by connecting to AC and holding down the power button until (hopefully) you see the sleep light flash, and hear a tone. Also try reseating the memory, and test the memory slots one at a time, leaving the other slot empty, and power on in each scenario. Bad slots are a common issue on this model. Also make sure you have a 65W AC, because a 45W won't power on this model.
thanks.. i ended up buying a new macbook and gave him my pc laptop.. i thought i might be able to salvage this one for my grandson.. i guess not..
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 846
1 Kommentar
Please explain further what you are after....what switch? What is wrong? Had had much experience with this model, but need more info. Thx.
von Danno
