Clock Issue after Complete repair
Hey everyone. New to the Forum but i was wondering if anyone could help me. I have been working on a iPhone 5C that was dipped into a dogs water dish (battery side) and then also dropped a few days after. When it got water damaged i turned it off, opened it and the only water damage indicator that was red was the one down by the battery, i let it dry out and everything worked fine, fast forward to a few days when it was dropped. The front screen smashed completely but still worked sort of. Enough to determain if it was worth fixing or not. So i ordered a new screen, a new battery, even a completely bare housing (was blue but wanted white) so i switched everything over, went flawlessly the only thing that does not or will not work correctly is the time. Ive tried resetting network settings, restore, full update and restore and set as a new iPhone, toggled the automatic date and time on/off, no matter what i do as soon as i lock the phone and let it sit, the clock either stops or jumps back a few minutes. Im stumped, do any of you know what could be causing this? The only thing i can think of is maybe the battery? I dont think it is OEM does this make a difference? Thank you guys for any input you may have.
Ist dies eine gute Frage?
1 Kommentar
Alright, so last night I had done a bunch of testing to determine if it is the battery effecting my Date & Time. What I had done was let the iPhone sit on the charger for 2 & 1/2 hours (until fully charged). During that time the Date & Time worked perfectly, Not even 15 minutes after I took the iPhone off of the charger, the Time went back about 5 minutes and started messing up again. So long story short While plugged in it works, While on just Battery power alone it doesn't. I will be ordering an OEM battery and swapping out the cheap one.
von John
