Zum Hauptinhalt wechseln
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Fragen Alle anzeigen
Frage geschlossen
1994 Toyota Camry starts but dies
My car was running great on my way to the store, then when I went to leave it started, after putting it in gear and going a few feet it shut off. I replaced the fuel pump 1 year ago and it's still working, had the top pulled off last year to replace a heater hose by pass, put new plugs in and check a few other things everything was in great shape, got a smog last month was told the emissions were better than last years! So I'm totally stumped how would I go about checking the injector regulater? I'm going to put in a new fuel filter, just not sure how to check the regulater. Sounds like it's not getting enough gas thanks for your input.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This will explain the fuel system test for regulator and other problems.
https://www.youtube.com/watch?v=AeVTZz0o...
hope this helps
War diese Antwort hilfreich?
Bewertung 2
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 828
