How to replace MacBook 2015 12 inch spacebar
I removed my space bar as it wasn't going down all the way, thought I should clean it out. I cannot get it back in so I can press the key down as beforehand, how do I go along to replace it, without having my whole laptop replaced or sent to be serviced?
Ist dies eine gute Frage?
5 Kommentare
You need to separate the white part of the key from the top of the key, the part that's anchored by the 2 long wires VERY CAREFULLY, then press the white part into the base by the little pegs. Then you press the black top onto the wires bottom side (one sided peg instead of two) first. You need to keep track of the orientation of the parts and be VERY CAREFUL when you remove the parts because the little pegs break easily.
von dianarwang
Do you know how can I buy a new spacebar? I broke some of the small pegs.
von csepeli
Yes, I have the same problem. Where can I orfer a space bar for a MacBook Pro (Retina, 15-inch, Mid 2015? Thank you, John
von john.mannino@att.net
Hi guys, same here. Did you find a way to get a new butterfly part?
von Thomas Wilde
I found this website but can't figure out which space bar I need to order. I have a mid-2015 MacBook Pro 15" Retina https://www.replacementlaptopkeys.com/ap...
