Put diesel in by mistake
I accidentally put diesel in gas tank. How do I fix it other than emptying tank?
Ist dies eine gute Frage?
Remove as much fuel as possible then fill it with fresh gas. It will smoke for a while and after a while you'll want to put carb cleaner through it to remove any heavy fuel that remains in the fuel system . If there's an inline fuel filter you may want to change that after you've gone through a tank of fuel .The oil in the diesel will cause a gas fuel filter to clog
War diese Antwort hilfreich?
if you did not put much in run it it will smoke and keep putting all the gas you can
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,772
