Zum Hauptinhalt wechseln
The Apple TV is a digital media receiver designed by Apple and released on March 21, 2007
What is the 4prong black port next the the IR plug?
ok so I pointed at it with the red arrow on one of the pics. I'm just wondering what that is. Is this a usb port? or a power slot? I cant seem to find ANYTHING on this thing. I found an internal bluetooth mod that went into the same slot but i'm afraid to try it. I also looked at schematics for this apple tv and nothing. Anyone have any good guesses?
maybe I can use it for a sata drive?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Not quite the resolution I’d need to be more specific, but it might be a diagnostic connector used by the OEM to test the mainboard.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
There are connectors you can buy that will allow you to use a SATA drive instead. I have not done it, yet, so I can't advise which ones are best. Also I noticed people on YouTube replacing the HDD (which is Parallel - "PATA" drive, similar to ones found in laptops) with a conversion board that allows you to boot from a tiny Flash media card. The one I saw that I think may work is a micro sized flash, that fits into an Compact Flash card that is itself an adaptor, for the larger flash unit. https://youtu.be/eg7nULtrquE?si=QABTmdJc...
von
Antwort hinzufügen
Manny O wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 875
