My Notebook is not able to start
Once I press the Power button, it seems that my computer starts like always do. But, somehow, after a few seconds of normal activity, the fan switches off and the computer remains in a state of apparent hibernation. During this process, the screen remains off and black, and does not turn on. In addition, the LED power button stays on all the time and the computer does not respond to any key.
My hypotheses are:
1. Something is wrong with the fan (not probably).
2. Something is wrong with the graphics or the screen (I don't think so)
3. Something is wrong with the BIOS (maybe the computer can't load the BIOS, maybe there is a problem with the BIOS battery).
4. Something is wrong with the processor (maybe there is a thermal issue or something worse).
Any ideas or possible solutions? I will try to unmount the computer and clean the inside...and see if that helps.
Thanks!!
Ist dies eine gute Frage?
Hi,
Have you tried starting it with the power adapter connected and switched on? What happens then? Same as when only on the battery or not?
von jayeff
Hi,
I tried starting my notebook with the following configurations:
1. Only with battery.
2. Only with power connector.
3. Both of them.
But in all cases is the same...
von Carlos Marques Bravo
do you get the bios screen ? or does the screen stay dark? have you tried a static discharge boot. Have you tried removing ram and replacing with know good ram. try ram in different dim slots 1 at a time . could be bad dim slot or bad ram.
von Jimfixer
I've got dark screen all the time. I've tried a static discharge boot (30s + 30s...). I've tried to swap RAM cards. I've tried to put one RAM card at a time in the different DIM slots. But viewing another posts, now I think that there is a high probability that the failure comes from the GPU. If finally that's the case, it's possible to fix the GPU?
Really stupid thought. have you tried connecting an external monitor to see if there is any display present at any stage. It might verify that your GPU has failed.
Also you might have this already but here is a link to the service manual for the HP G62. http://www.hp.com/ctg/Manual/c02542455.p...
von jayeff
2 weitere Kommentare anzeigen
