Zum Hauptinhalt wechseln
8th generation of Chevrolet's full sized SUV, based on the GM GT400 platform.
18 Fragen Alle anzeigen
Have no brake lights hazards or turn signals
I'm not sure how to work on the suburban!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Here is some info for you.
Fuse No.1 is for your brake lights and your hazard lights. If no lights after fuse, if found blown, is replaced check your light globes. If nothing works check that the fuse hasn't blown again. Fuse 16 is for the turn lights. If the fuse is blown and then when you replace it you find the the turn lights flash rapidly (depending on whether you select left or right) there will be a blown light that you need to replace as well. If the turn lights don't flash and you don't hear the flasher unit clicking, then you need to check/replace it. (see last image for its' location).
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
And what if none of that works?
von
Did you fix lights on suburban. What all did you do
von
Antwort hinzufügen
Virginia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 46
Insgesamt: 26,449
