What you're experiencing is a blown inverter. This is the part of the monitor that directly controls the backlighting. The fact that the light comes on at all shows that the lights themselves work.
Finding a specific inverter can be a pain, but I've found that eBay* is your friend in these cases. I stick with "Buy it Now" and "Top Sellers" with 94-98% approval and at least 1500 transactions completed. Read the descriptions CAREFULLY and know what you're getting. Also be sure you know their return or exchange policy...almost all sellers I've seen will not accept returns, but most will accept exchanges in case of dead-on-arrival.
I deal with blown inverters on laptops all the time. Working on a G4 Titanium DVI (A1025) now with that exact problem. Found the guide right here on iFixit. I'd never worked on a Mac laptop before, so I wanted to be sure to do it right...I need not have feared, as it's easier than any other laptop inverter I've ever replaced. (The same is NOT true for most of them, apparently!)
I didn't find any manuals here for replacing inverters on LCD monitors, but I might do a couple if I get a chance. While the functional part is the same, the make, model, and procedure for doing it is a bit different for almost every monitor out there. Just Google (or Bing or Yahoo or *search engine here*) it and you'll probably find one.
Edit:
I checked out eBay once I found the correct model number (931BW). There are several listings for a replacement power board. This is where the inverter is located on your monitor (as Shawn pointed out). The prices seem reasonable (the first 2 listed were $23), so it shouldn't be a problem to get it replaced, once you can get it open.
Unfortunately, I had less luck with the service manual. I found a couple that claimed to have it, but one wanted registration (didn't really want to do that) and another wanted money, but I didn't see how much. Wish I could help more on that part.
*Update:
Since I wrote this, Amazon (among other places) have started offering products from third-party sellers/resellers and are fine alternatives to eBay. However, the same cautions apply. Know who you're buying from. Do your due diligence. I'm not here to promote any one source, I simply provided my own experience as a starting point. Good luck!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
19
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
26 Kommentare
Might want to update the "device" listing to the 931BW. I checked Google and Samsung and it's the closest to the 931sw you listed. It makes a difference when trying to research! :p
Also, how long have you had it? According to Samsung, it has a 3 year P/L warranty. Not sure what they require, but it might come in handy! Seems this model has a lot of known issues with the inverter. Once I changed the sw to bw on my Google search, I got a TON of hits for it.
von Jerry F Nerviano
if it shows for a few seconds then it shuts down and you can still see the image? that means the 12 volts going to the inverter board is not steady or the inverter board is faulty. from experience, I usually find a blown fuse on the inverter board. replace that and it should be fine.
von Waleed Rishmawi
Hi,
You might want to tried testing the Caps of the power board, normally they die after time, check out this post for more info:
http://www.fixepedia.com/index.php/2016/...
von silverplate
ppl me problem is next : me PC monitor works until i turn off me pc and i go to sleep and next day when i turn on PC i go t pictures on me monitor for 2sec and disepire and what i do?? in start of me problem i found solution 5-6 click on power buton of monitor and i got pictures and monitor works totaly ok until next day and new turn on me PC can some1 tell me are is problems in capacitor or what? tyyyy
von zdanilo
You fixed it for me!
I had this problem now with SyncMaster 2494HS. Start and shows image for 1 sec then goes black but not turned off.
Mashed the power button like 10 times and then it's on and stays on!
Thanks from the future!
von norditroll
21 weitere Kommentare anzeigen
