Zum Hauptinhalt wechseln
HP's G72 laptop has a high-definition 17.3" diagonal display, a stylish design and decent specifications. It also makes a decent budget desktop replacement
10 Fragen Alle anzeigen
No bootable device found
This is the second time this problem has occurred, the first time iit happened i changed the harddrive but the problem has appeared again!
Ist dies eine gute Frage?
Bewertung -1
4 Kommentare
Hi,What is the model number of your HP?
von
Its hp g72.....
von
In bios harddrive is not detected.... I tried another its working fine.....
von
Hi,
The question to ask yourself is , why are the HDDs failing so soon, especially if the 2nd one was new.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I would consider also changing the hard drive cable with the drive: HP G72 Hard Drive Replacement
What is happening to the drives and do they work in an external enclosure or universal adapter?
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Its being detected as an external but u cant see any files in it... Can only see 2partions
von
Antwort hinzufügen
Murtaza Kadibhai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 181
