Zum Hauptinhalt wechseln
1,86 GHz oder 2,13GHz Prozessor, 128 GB oder 256 GB Flashspeicher
147 Fragen Alle anzeigen
Frage geschlossen
Broken connectors while changing I/O board.
“Changing i/o board macbook air 13" 2010. I broke off two connectors when changing. Do you know where I can purchase a couple of new connectors?”
Update (01/08/2016)
Here are some images:
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare
Upload a picture so I can see the damage.
von
It's just the connector end from the speaker? The thin black plastic piece? do you still have it?
von
It broke apart, unfortunately.
von
Thank you. If I leave it connected for the time being without tape, what could short, just the speaker?
von
That's a tricky question you could short the i/o board maybe just the speaker maybe nothing but I would'nt leave it like that unless you had kapton tape which still is not the best solution.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You'll need to order a new or used working speaker assembly .
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 85
