Zum Hauptinhalt wechseln
Vierte iPad Generation mit GSM, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1459.
43 Fragen Alle anzeigen
iPad 4 after Digitizer replacement some areas don´t react
Hello guys,
i replaced my iPad 4 front panel after it was broken but now i have the problem that the new digitizer only reacts at the top and bottom area, in the middle of the screen it doesn't response. I thought the Digitizer is damaged so i took a new one but same problem only in different areas.
What can it be? Is it again maybe a damaged digitizer or maybe a short circuit some where or something else?
Really appreciate if you can help me out.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Most likely the digitizers your using are from third party vendors, and you're having third party problems. I would try a quality digitizer. It is possible that you've damaged the alligator connector, while assembling it
iPad 4 Screen Digitizer Assembly
iPad 4 Screen Digitizer Assembly Bild
Produkt
$39.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you for your help. I will try a new one.
von
Antwort hinzufügen
fuad1177 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 91
