Zum Hauptinhalt wechseln
The iRobot Roomba 655 Pet Series vacuum manufactured in 2012. Costco exclusive.
29 Fragen Alle anzeigen
Why is the battery light flashing on my roomba?
The battery light and the clean light are flashing the battery light is amber color and the clean light is green but they are both flashing and it does not appear to be charging.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
ajfaith1012, by your description it sounds like a problem with the battery charging. Either your battery is bad, the charger is bad, or the charging circuit inside your Roomba has failed. You could start with a new battery and after that try an external charger for Roomba batteries.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
Does it take batteries Even though it's charging on outlet
von
Where's the batteries located on irumba
von
OK can't find it
von
Elena Chreene what model is your Roomba?
von
After trying the standard and much covered Power Reset buttons press (see Youtube.com) I still had an orange, flashing (slowly) battery icon. I did the reset three times and left it to charge overnight. Still no luck, so I unscrewed the bottom plate (how you access the battery) and installed an old but still working battery. My Roomba 655 then ran for 12 minutes, which is the length of the charge that battery holds. I have a replacement battery in there now and it WORKS!
Bewertung 0
3 Kommentare:
It still does not work it comes up with a error number 0 0 7
von
Should I order a new battery charger for it
von
Should I go ahead and order a battery charger for my 665 roboma
von
Antwort hinzufügen
ajfaith1012 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 148
Insgesamt: 27,379
