Zum Hauptinhalt wechseln
A place to find useful toaster oven repair and disassembly guides.
59 Fragen Alle anzeigen
How to stop the bell
I have a rival toaster oven similar to the one in the picture. I work in a cubicle area at work so everytime I turn it on the bell rings. Is there a way to turn unplug it or something so that the timer still works but the bell is silent.?
Thanks
Latrael
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
I have exactly the same toaster oven and question.
von
@yeltommo what model is your Rival Toaster Oven?
von
Okay, I lied. It's not exactly the same toaster oven in that it's a Black + Decker rather than a Rival, but I suspect it's the same design. It's called the 2 Knob Toaster Oven, but I can't find a model number.
https://www.target.com/p/black-decker-15...
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Actually I just did this and it wasn’t too hard. New basic Black and Decker toaster oven that cost $40. Took out enough screws to allow front panel to pull out about ½” on the top edge. There was a bell on the back side of the timer knob switch that I could see when I looked down inside. Seems like that is pretty standard for these contraptions. I drove a 3” screw from the top down between the bell and the switch so it’s snug. i made sure it was out of the way of other electrical contacts for the other switches/knobs. Now it just makes a sort of self-satisfied click when the timer is done. Put the screws back in and heated up some chicken nuggets without letting everyone in the neighboring studios know lunch was ready. Yay!
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
@arvidt great answer to an old question. Describes exactly how to stop the pestering dining noise of the toaster oven. Should have taken some pictures of how you did this, so we could have a guide for it as well.
von
..I would include a legal disclaimer of liability.. dude, your Lawyers will thank you 😉
von
Hilfreichste Antwort
Most of these have a mechanical bell which is part of the windup timer. These are difficult to open and put back together.
Have you looked for an electronic timer version of toaster like a Breville mini toaster. At least you could then disable to electric buzzer unit.
Bewertung 4
3 Kommentare:
Thanks. The question is, how difficult? Let's assume I can't afford a new one. I read somewhere that someone was able to pull or bend the clapper away from the bell enough so that it didn't reach the bell when the timer ended. Not sure how similar his unit was. Are you suggesting that it's hard to disable the bell without disabling the timer (which in this case is integrated with the toasting/cooking function)?
von
Most of these timers are not designed to be opened so you end up breaking it. But even if you do open it up the design of the gear works of the timer makes it hard to disable the striker. The only thing you could do is pad the bell so its not as loud.
Have you tried locating a broken stove of the same series to practice on?
von
No, I haven't. If it's that hard, then it's probably not worth it, though padding the bell would definitely be better than nothing.
von
Dude, we are sending people to Mars soon.... 🙄 has our society become so mechanically reclined as to not stop a bell from ringing? 😉
A mechanically operating bell is easy, just lots of screws....so many screws...🤣
Bewertung 0
Antwort hinzufügen
latraelmayo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 9
Letzten 7 Tage: 66
Letzten 30 Tage: 302
Insgesamt: 14,236
