Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
iPhone 4S Logic Board Replacement, Where to buy - kksilvery
Recently my iPhone is not working , Apple Logo loop when turn on then t turns off, according to my engineer , it requires logic board replacement.
I tried to restore it by putting it on recovery (NOT DFU) , it showing up iTunes error 29.
Where can i get clean imei board under 40$. Im from india if any of you have a spare or a board which do not need then sell it to me via courier or ebay etc etc.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hi,
I had this same issue with my iphone 5c. It turns out that it is to do with the antenna that is near your battery. I suggest taking it out and putting it back in again. Please also clean it! So many people get it wrong but your oils from your finger can mess up the system, clean it with windex (not too much though). Also going back to your question the best place to buy is either gumtree or ebay. If you want a trusty motherboard for a little bit more money I would get if from here! At least you know it wont break. Please help me as well. Questions and comments on my page: Iphone 4 does not turn on after getting to step 9 on replacing screen, it might have something to do with the cable however I don't know. Thanks,
Max
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
hope it helps!
von
Kksilvery thank you for good suggestion .... Unfortunately it dint work out for me .
Kksilvery.
von
Antwort hinzufügen
krishna kumar silvery wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 89
