Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Wi-Fi is grayed and No Bluetooth
My phone6 wifi connection is greyed out and blue tooth is not working, I have tried all the method post to web, the problem still not Fixed. look like have need replacement of the iPhone 6 Wi-Fi Antenna replacement.
Can someone tell me is
iPhone 6 Top Left Antenna
had fix the problem using above wifi replacement or any issue.
iPhone 6 Top Left Antenna Bild
Produkt
$9.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The wifi antennae is the first thing I would look into, after that it's like what jump1n said, you'll have to have the board worked on
There isn't a guide for it, now. You're not supposed to use the teardowns as guides. But I do it all the time
iPhone 6 Teardown
Produkt
$9.99
War diese Antwort hilfreich?
Bewertung 1
I had the same problem and with the iPhone 6 this is a very unknown issue and I researched into it and found this. Something may of come loose connector wise check thembut in setting under wifi address it says NA then yes try those but I reckon it's the wifi chip has benn moved from its place on the motherboard, replace that and it'll be good as new,
Hope I helped
Regards
Lucas
Bewertung 0
Antwort hinzufügen
hklha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 554
