Zum Hauptinhalt wechseln
Drahtloser Kontroller für die Xbox 360
92 Fragen Alle anzeigen
How to repair a loose analogstick?
so right now my xbox 360 analog sticks are all suffering from the same problem is that the analog stick is loose and wont fix its self back to center it makes it really annoying in game that my character is moving ever so slightly off in to a direction.
so my question is how can i fix a the loose analog stick?
with out any solder or having to buy a new controller.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 10
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
The drift is a very common problem but infortunately no real fix. Cosmetic issues are really the only thing that is cost effective to be fixed. You can get a used controller for like $20.00 to $25.00.
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
thanks, i guess i will have to look for some old controllers
von
For about half the price of buying a used controller here is a firstaid/rebuild kit for it:
http://secure.llamma.com/catalog/product...
Bewertung 3
You need to change the potentiometer. You can get a potentiometer in good condition, by an original xbox control.
Bewertung 1
1 Kommentar:
My hole Joystick is broken off
von
Its always good to have spare joypads around, a 10 bucks thingy usually fits the need, also old ps1 dualshocks seem to have very durable parts
its as simple as desoldering the sticks and put in the harvested on and solder it back
most analog sticks except for ps3 and nontendo ones are the same
and the pcb of a dissected pc joypad can be used to make old joysticks like sidewinder or even the old amiga thingies to work with usb
Bewertung 0
If it works fine, but is just loose then follow the repair guide to take it apart and put a DAB of silicone on under the stick. This way you can still take it off it you want to change them out later. That's what I did and it works perfect. Hope that helps!
Bewertung 0
can i see bord of controller's charger
Bewertung 0
Antwort hinzufügen
Gorillahouse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 35
Letzte 30 Tage: 149
Insgesamt: 89,169
