Zum Hauptinhalt wechseln
Das LG G4 kam Anfang Juni 2015 auf den US-amerikanischen Markt, wie immer mit dem Fokus auf High-End Technologie und einem raffinierten Design, was es als Permiumsmartphone aus der Masse herausstechen lässt. Jede Version des Telefons hat eine unterschiedliche Modellnummer, abhängig davon, ob es von einem Telefonanbieter oder LG selbst als US Unlocked oder Internationales Modell verkauft wurde.
74 Fragen Alle anzeigen
Cant make calls, saying my lg is on airplane mode
My lg 4 g with metro won't let me call out, saying airplane modes on but its off
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 9
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Hi,
This link may be of relevance to your problem.
http://forum.xda-developers.com/sprint-g...
You may also wish to try a hard reset of your phone to see if this resolves your problem.
Be aware that a hard reset will erase all your downloaded apps and user data and restore your phone to a factory default condition. It will be like when you first bought it.
You may wish to backup your data first.
Before performing a hard reset ensure that the battery is charged. Do not perform a hard reset with the charger connected.
Here is a link that shows you how to do it.
http://www.hard-reset.com/lg-g4-hard-res...
Be patient, it takes a few minutes.
War diese Antwort hilfreich?
Bewertung 3
Try change the battery that help me
Just that
Bewertung 1
2 Kommentare:
I just got my new battery, put it in, crossec my fingers, toes, legs and ❤, booted up and Volia! I'VE GOT PHONE PRIVILEGES
von
In case you don't read icons, that's a very big, and grateful, THANK YOU G4g4!! SMILES GOOD 4 DAYS ON END
von
My sons phone did the same thing. I cleared the cache then instead of message to turn off airplane mode it said it needed 911 installed. Somehow the 911 phone number got deleted so when I added it back in, the phone now works, doesn't give error messages and can make calls
Bewertung 0
For mine I had to reseat my sim card. I opened the case to see if it would do the same thing with no sim card. I pushed my sim card back a little and removed the sticker on top that was coming off. I expected it to say no sim card when I turned it on but to my surprise it said service. Finally, the problem was over. I dont know if it was pushing to sim card back or taking off the sticker (maybe it was snagging something) that worked. But between the two. It worked.
Bewertung 0
Antwort hinzufügen
thomassechler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 50
Insgesamt: 34,766
