Zum Hauptinhalt wechseln
Dell Precision M4600, a "15.6" inch laptop, part of the Dell Mobile Workstations with strong processing capabilities, was released between 2011 and 2013 by Dell computers.
2 Fragen Alle anzeigen
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
Bewertung 2
9 Kommentare:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
von
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
von
I`ll replace my screen and feed you back with the results. Thanks Man
von
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
von
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
von
4 weitere Kommentare anzeigen
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
Bewertung 0
Antwort hinzufügen
mahmoud eldeep wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 8,609
