MacPro does not power on... and does not attempt to boot
This machine has not been used much. It was purchased in 2011, and has been idle for about a year.
- No light appears at the front where I push the start / on button
- No internal sounds are evident
- I replaced the BR2032 with a CR2032 and no different outcome when I push on button
- Not much dust inside
- I removed the graphics card and re-seated. Did the same with CLU shelf and disks.
- A red light flashes, if I attempt to plug in while CPU shelf is out, so there is power to the mother board
It was working fine when I shut it down a year ago.
Any ideas?
Thanks, John
Update (01/24/2016)
Hi Jim,
The pics are a bit dull. This pic should show that memory slots 1-4 have 1GB stick, slot 5 has 4 GB and slots 7-8 have 1 GB sticks.
I believe that this is way it came. Above, I indicated that my son my have borrowed some memory but I was wrong.
Thanks for your interest,
Max
Update (01/27/2016)
The upload tool is a bit funky.
Still funky... The point with pics is that there is virtually no dust.
Ist dies eine gute Frage?
9 Kommentare
Are any of the internal diagnostic LEDs on?
von mayer
Hi Mayer,
Excellent question... I finally found the Apple tech guide here:
URL = http://tim.id.au/laptops/apple/macpro/ma...
And the advise in the Diagnostic section asked the same question you have.
I will get to this tomorrow in Toronto time... and then re-port my findings.
The MacPro machine is an 8-core... I have been looking at the memory...
There are four sticks of 1 GB each on the right most memory bay slots 0-3
While there are three (3) sticks of 4GB in the left most bay in slots 4-6.
I have a sense that my son liberated one stick of 4 GB.
So I pulled the 1 GB stick from slot 3 in what I think is in accordance with the Guide,
But it made no difference.
I appreciate your response,
Max
von Max Entropy
When attempting to diagnose this machine, always take it back to the original configuration first, that includes any added PCI cards, Added RAM and added hard drives. Also knowing the exact machine is helpful.
von mayer
Ok, so I did the diagnostic tests and the first failure observed was re: Page 35, wherein the Apple Guide asks me to 'momentarily jumper' the SYS_PWR pads on the motherboard.
I did this by itself and then while holding down the Diag button.
The expected results from Apple Guide was the fans should turn slowly... etc...
My results were nothing happened.
I also reset the RTC via the button next to the battery BR2032.
Lastly, when plugging the power cable in, both Red lights entitled OVTMP CPU A and B flash momentarily red, which seems to be good.
Curiously, Apple does not offer advise for the SYS_PWR diagnostic when it fails.
Any ideas or observations would be helpful,
Max
von Max Entropy
Would you go here and input your serial number so we know your exact machine: http://www.everymac.com/ultimate-mac-loo...
von mayer
4 weitere Kommentare anzeigen
