Zum Hauptinhalt wechseln
Repair guides and support for computer monitors produced by Samsung.
87 Fragen Alle anzeigen
Frage geschlossen
Backlight issue: dark semicircle appears on right side of screen
So this is a second hand Samsung SyncMaster S23B300 (23") HD DVI monitor but worked fine when I first got it, daily use, no issues till recently so hopefully the previous owner didn't know about it.
The issue is, when I turn the monitor on after it being off, a dark semicircular shadow radiates from the right side. If I press on the plastic frame, things return to normal, and after a bit of fiddling I can get it stable and make the screen appear normal again. However, this is becoming more frequent and more difficult to remedy each time it happens.
It seems like a small issue and I am used to fixing things myself, I can solder etc, but I have no idea how these monitors work. I am under the impression that it could potentially be a capacitor, or even simply some bad connection. Should I just open it up and have a go? Any tips?
Pic: http://i.imgur.com/ImI9tRV.jpg
Usually forget to take a pic when PC first starts up, so excuse the peek into my Youtube habits. I have noticed its slightly darker on that side even when the circle is gone.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Devin Valentine that looks like either a diffuser issue (most likely since when you "press on the plastic frame, things return to normal") or a backlight LCD issue (less likely). Definitely not a capacitor or connector issue. To possibly fix it you will have to disassemble the diffuser sheets within the panel and take a close look at those.
War diese Antwort hilfreich?
Bewertung 2
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 234
