Why does my tablet keep going on and off
What do I do when my tablet comes on and then goes off, and keeps doing that??
Ist dies eine gute Frage?
Sounds like you have a boot loop problem as I do as well. If you go to YouTube and type in what your device is and boot loop (example- RCA tablet boot loop) you will get videos on how to try and fix it. I did the same but am still having the problem. Maybe you will have better luck than I. Sorry I could not give you an exact answer.
War diese Antwort hilfreich?
That is if you have another device to go to YouTube. Should have put that in the first response. My bad. Good luck!
This can also be caused by a bad battery or a damaged charging port. Give the charging port a really good look under bright lights. Better yet use a magnifying glass. If a magnifying glass isn't available, you can try taking a picture of your charging port with your cellphone and zooming in on the picture to inspect the pins.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 130
