Zum Hauptinhalt wechseln
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
20 Fragen Alle anzeigen
Will not auto connect to HDMI
Hello,
When I turn on my TV it used to recognize the hdmi cable and auto connect to that source. Now for some reason it auto recognizes the TV source and I have to change the source everytime I turn on the tv. How can I get it to automatically connect to the HDMI?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Is the antenna input the last input selected before you switch OFF the TV?
Have you tried selecting the HDMI input, connecting to it successfully, then switching OFF the TV, then switching ON the TV and seeing if it connects to the HDMI?
If it works it is 'remembering' its' last connected input and connecting to it on power on.
If it doesn't and it connects to the antenna (default) input and still maintains all the other user preference settings plus the correct TV channel information, settings etc., it may be just a glitch in the software which may be resolved by 'resetting' the TV. Be aware that when you reset the TV, it will have to be setup again, as it will be restored to a factory default condition. Like it was when you first got it.
Here is a link to the User Guide which shows how to reset the TV.
http://www.manualslib.com/manual/361614/...
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
bafitsoul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 4,462
